i need to use my phone why is nobody contacting me 343-263=6090
  • 25 January 2017
  • 1 reply
  • 4 views
put a $10 voucher on need to use it for a booster instead
Best answer by Daniel Kim 26 January 2017, 00:10
Hi Cher, I'm kind of confused by your question. If you purchased a 10$ voucher you can add it to your account in prepaid self serve and use it to buy the booster. Or do you mean you accidentally bought the wrong booster?
1 reply
