i added a data booster to my phone and it's not working?
I just used my credit card and added 30$ to my account then i added the booster, why is the data not working on my phone?
is the data turned on?
Also, if your phone was not a Koodo phone originally, can you check if your APN is set up correctly? http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on-my-non-koodo-phone
data is turned on, i turned off phone and turned on again. It's an unlocked phone.
What kind of phone is it? Blackberries running OS 7 or older are not eligible for prepaid data. Did you check the link Sophia posted? Without those numbers in your phone, you won't be able to use data.
omg sophia, You're a genius thank you so much for that link!!
Glad you got it working 😃
