How does top up work?
What will be topped up, basic prepaid plan + boosters i chose? I need to plan enough money to cover that every month? Need to understand how much money to chose in top up.
Best answer by Sophia 30 May 2015, 22:44
Hi Sylvie, When you top up, if you do nothing, the money will be used to renew your base plan until it is depleted. If your funds run out, you need to top up again with at least the amount owing to renew your base plan again. You can also choose to use your funds to buy a booster, obviously you need to have enough to get the one you want 🙂
1 reply
