Best answer by Sophia
Hi Blair, It's really very easy, just buy a prepaid Micro SIM ($20 from Koodo, though you might be able to find it cheaper on eBay). Then all you need to do is activate the new SIM card in Prepaid self service, and your number and plan are transferred to the new SIM. Easy as can be
