how do i read my incoming text messages
I have a lg optimus l3 e400b and cannot find my incomming text messages why? where do I look for them?
Bonsoir Louise! Utilisez l'application de Messagerie texte 🙂 Good evening Louise! Please use the text messaging app! 🙂
how do not get my text messages where do i find them first?
The picture I posted shows you what app you need to use to read/send your SMS (short for text messages). The app itself is very straightforward. You simply need to tap its icon to open it up and from there, there's gonna be a list of all your messages. You simply tap on any of them to read it. To send a new text message to someone from scratch, you open the same app, and in the menu bar you click the "+" icon. All you need is your recipient's phone number, which you enter in the bar at the top. Then you type your text, then "Send" (sometimes it's a right-pointing arrow icon) and you're done! 🙂 Vous pouvez aussi continuer en français si vous êtes plus à l'aise 🙂
