How do I go from a prepaid plan to a monthly plan?
I have an iPhone 4 I'm on a prepaid account right now I am from Woodstock Ontario and i want to switch to a monthly plan i have been on the prepaid plan for only 1 month and just paid for the next month and i also have to prepaid sim card so how will this all work?
All you have to do is sign up for a monthly plan as a new Koodo customer and tell them you want to port your Koodo number over. You will have to buy a new Koodo SIM card as a prepaid one wont work and they will also preform a credit check so make sure you bring a valid id and other piece of information. A list of what you need can be viewed here: http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/do-you-perform-a-credit-check . i would suggest using up the rest of your money on your prepaid account as you will lose this when ylu switch but if you dont care about that feel free to switch whenever you want!
Allan wrote:
All you have to do is sign up for a monthly plan as a new Koodo customer and tell them you want t...
You may be able to transfer the balance of your prepaid account credit if you talk to them nicely, but you should use up any talk or data boosters as these are non-transferable and non-refundable.
