how do i forward a call from a caller
Not sure I understand what u mean by forward a call to a caller. Can u explain what the outcome your looking for is?
well when my son calls I need to forward his call to another person while he sits and waits for me to forward his call
Glenda Martin wrote:
well when my son calls I need to forward his call to another person while he sits and waits ...
How to activate Call Forwarding:
Press Star key (*) followed by 72.
Enter the area code and number you want your calls forwarded to.
Press Send or Talk (depending on your phone) and an automatic prompt will confirm the feature has been activated.
Also here is the link to that info. Click " how do I use call forwarding"
http://help.koodomobile.com/plans-add...
I don't believe you can transfer an incoming call to another phone number with Koodo's service. You MIGHT try three-way calling, then exit the call, leaving your son and the other participant in conversation, but I'm not sure it will work once you exit the call.
If you call forward incoming calls to your phone as Chadwick suggests, all incoming calls will be forwarded to that number, not just your son's calls.
If you can provide a bit more detail of what you are trying to accomplish, the community might be able to provide more suggestions.
Userlevel 3
dfbutt, I think you are on the right track here and what I found was conference calling is device dependant so G Martin may have to consult the manual for that particular device.
