help
How can I change my cell number to a local number ?
I don't know 100% if it's possible on prepaid but if you are registered for Self Serve then the option will be there somewhere. Otherwise, you can call customer service and have them do it.
Jonathan I wrote:
I don't know 100% if it's possible on prepaid but if you are registered for Self Serve then the o...
Self serve would be free, but I don"t believe that if would cost you anything, if you are moving to another province if you called in.
