Help
HI, I just activated my phone but its not letting me do anything. Is there a step I missed or something else?
figured it out!!!
Amelia Dykens wrote:
figured it out!!!
Glad to hear you got it working it does take a little time for the phone to actually become activated. For future reference just pop out the battery and SIM Card for a minute or so then replace them and try it again. Whenever you have an issue that you can't figure out always try doing the battery and SIM Card pull as it usually will solve many issues that nothing else seems to fix.
