does the prepaid plan work if i travel within canada
I live in montreal and traveling to toronto. I have the 35 dollar prepaid plan. will my phone work?
Yes. Your incoming calls are included in that plan, no matter where you go in Canada, and your outgoing calls are covered up to the number of minutes you have in your booster.
Yes. It will work anywhere in Canada. Now, with the 35 you get unlimited incoming calls nationwide. So you won't have to dip into any minutes to receive calls. It gives unlimited outgoing after 5pm, which also applies nationwide. There's no local roaming limitations. It's unchanged from your usage in Montreal.
