does taking the $15 unlimited text plan prevent making phone calls
unable to make calls or receive calls goes right to voice mail
You will need to add an airtime booster in order to make calls. Log into selfserve>boosters>buy one of the airtime boosters. These boosters can be used to their ENTIRETY as long as your account is kept topped up. The 500 minute booster has the best bang for your buck.
Sounds like you are a prepaid customer on the unlimited texting plan. If you want to make or take calls you will need the $5 add on that gives 50 minutes worth of talking.
