Do province-wide minutes include local calls?
  • 19 June 2020
  • 3 replies
  • 81 views
I have the prepaid base plan that includes 500 minutes of province-wide calls/month. Are local calls counted as part of the 500 minutes per month, or is that unlimited?
Best answer by Goran 19 June 2020, 03:12
Local is part of the 500. You don't also have unlimited local unless it explicitly states so. The local is part of the province.
Sorry for the second question but do these minutes only apply for outgoing calls? (Do incoming calls count as part of the 500 minutes?)
Yes, Incoming calls use your minutes.
