Do I need a prepaid card every time I activate my prepaid phone?
i do i need a prepade card every time that i need to activate my prepade phone
Every time you activate it yes
Hi Chantal, I have changed your post into a question, as I suppose that is what you meant it to be 🙂 Can you explain what you mean? I'm not entirely sure what your question is, but if you mean do you need to top up with $15 each month to keep it active, then the answer is yes.
