Disabling voice on sprepaid plan
can I disable voicemail on a prepaid plan?
It can't be disabled but you can turn the option to receive voicemails off.
It can't be disabled but you can turn the option to receive voicemails off.I think Sherlock answered this here: http://community.koodomobile.com/koodo/topics/how_do_i_permanently_disable_voicemail
Thank you both for your prompt reply.
