credit card wont go in
  • 19 December 2018
  • 2 replies
  • 90 views
credit card will not go in because will not accept a expiry date of 2025 on prepaid self serve
Can you use another credit card for now? They might be able to manually add your card if you contact Koodo.
Koodo needs to update the website so it will accept cards with expiry dates past 2024.
Can you top up by calling 611 instead?
