Canada-wide DAYTIME CALLS
  • 28 May 2015
  • 157 views
PREPAID ------------- I know that the "Canada-wide" minutes means the following: If you're on a Canada-wide plan, your anytime minutes can be used to call anywhere in Canada from anywhere in Canada without paying long distance rates! With our great Canada-wide plans, every call you make within Canada covers you from coast to coast at no additional charge. But what does Unlimited Canada-wide DAYTIME CALLS mean? Does it mean I'll still need to buy minutes to talk on the phone? Does it mean that during evenings and nights it won't be unlimited, nor will it be Canada-wide?
Hi Mylie, I am going to assume you are referring to the 50$ base plan from the pre-paid site. You already have unlimited evenings and day time included in this plan so pretty much unlimited canada wide calling. The site does have it somewhat confusing the way they have unlimited evenings checked off and then further down unlimited daytime calling.
Yes!!! Exactly!!! It is so confusing to precisely see that the unlimited evenings and unlimited daytime calling are both checked off. So just to be clear, I won't need to by extra minutes (booster - talk) for that $50 plan, right?
Yes!!! Exactly!!! It is so confusing to precisely see that the unlimited evenings and unlimited ...Not for airtime no. This plan still does not include Data so if you needed data you will need to get a booster for that.
Yes!!! Exactly!!! It is so confusing to precisely see that the unlimited evenings and unlimited ...This is great info!!! Thank you!!! 🙂 And, if I may ask you another question??? I see that Koodo sells phone specifically for pre-paid... but if I don't like any of those and rather buy new model, say Samsung Galaxy S6 edge... will the prepaid plan still work with it? What will I need to make that phone work with koodo's prepaid plan???
Yes!!! Exactly!!! It is so confusing to precisely see that the unlimited evenings and unlimited ...The S6 Edge would work with a prepaid plan. However, they will not sell you a S6 Edge as a pre-paid customer. The selection of phones under pre-paid are the only phones Koodo will sell you for pre-paid. You are always able to go to another store, buy an unlocked one and bring it to Koodo if you wish.
Yes!!! Exactly!!! It is so confusing to precisely see that the unlimited evenings and unlimited ...I think I'll buy a Note Edge or the S6 Edge, factory unlocked on Ebay... Samsung doesn't sell directly to particulars and all the stores usually have the phones locked to a specific service provider... Thank you so so much for such precise and concise information! I really do appreciate!!! 🙂 A +
