Can I use any unlocked smart phone on Koodo Prepaid?Can I use a Koodo locked Iphone 4 on Koodo prepaid base plan ($15)
Yes, you can use a Koodo iPhone 4 with prepaid.
Userlevel 2
same answer as the last one you posted. visit a koodo shop - get them to test out your phone to make sure it works. purchase a MICRO SIM - $20. and any additional top up vouchers while at the store. go to - activateprepaid.koodomobile.com and create a self serve account. Get $20 of credits upon activation - you can use this towards your $15 base plan.
