Can I still use my Samsung Ace when I switch to prepaid?
  • 15 March 2015
  • 7 replies
  • 17 views
I am on a Koodo monthly plan using a Samsung Galaxy Ace GT-S5830D. I want to switch to prepaid and go ahead and order a sim card. Can I be sure that prepaid will work on my phone without having to make a trip to the mall? thanks! Yes, I know the phone is awful but I already own it:)
I think you will need a prepaid SIM for that if I'm not mistaken... Therefore, to get one you would need to go to the mall .
Will it work? Yes But you should seriously consider upgrading your phone.
Will it work? Yes But you should seriously consider upgrading your phone. you buying?
Yes, you'll just need a prepaid SIM card from a Koodo shop (or online I believe). They're $20+tax but come with a $20 activation credit once you put it on your account.
Yes...I should be able to do it all on-line, but the sim is a non-refundable purchase so I'm just trying to be absolutely perfectly sure that my phone is prepaid compatible.
buen dia aqui quien Cuenta con la rom stock para este modelo
Userlevel 4
Hi Daniel! Wish we could help but we can only offer answers in English in this forum. Thanks!
