Call Forwarding on prepaid
  • 13 August 2017
  • 4 replies
  • 393 views
I have a prepaid phone with "$15 Unlimited Messaging" plan which includes Call Forwarding. How do I activate and deactivate Call Forwarding?
Call forwarding on prepaid [i]does not work AFAIK. Check all the [b]Related Conversations on the right, but your answer is in this one:
https://community.koodomobile.com/koodo/topics/call-forwarding-on-prepaid
Actually, I found a way in Phone app / settings (on Android) where I changed the number for "when unavailable" from the voicemail to the number I want.
Thanks for the answer, anyway.
Actually, I found a way in Phone app / settings (on Android) where I changed the number for "when...You've lucked out. Hope your fix survives your next reboot.
When I do the same on LG G3, Android 6, I get a [b]Call settings error. [i]Network or SIM card error.
Actually, I found a way in Phone app / settings (on Android) where I changed the number for "when...Maybe, but works for me as I plan to leave the phone off.
Also, make sure you write the number in the same format they have it there, in my case was +1416.......
