Base plan change - booster loss?
  • 18 August 2019
  • 3 replies
  • 347 views
I want to change base plans to take advantage of the 250Megs of data offered on the PPD $15/30day plan. I currently have the old 15/30 plan without the data. I also have a bunch of US boosters as well as around 800 mins of CW talk minutes. I've seen the Koodo website do some weird stuff over the past year or so (booster loss etc - which I had to plead with CS to get back). Do I dare risk it???
Boosters should not be affected at all theyre separate from the base plan completely
But probably not a bad idea to take a screenshot of my existing boosters before making the change????
Userlevel 4
That is what I did, but everything worked out fine. Make the change right before your renewal date as it happens right away.
