Any way to return a purchased add on booster and get money back? help!!!
Any way to return a purchased add on booster? I have 600 unused minutes and want to upgrade to a prepaid base plan with unlimited calling, but I want the $30 i spent on the minutes back.... help!!! Currently using the $15 base plan.
Unfortunately no boosters are non refundable.
Unfortunately no boosters are non refundable. Too bad, thank you for your help!
Do remember that the base plan offers province wide calling where the booster is good for Canada wide.
Do remember that the base plan offers province wide calling where the booster is good for Canada ...Upgrading baseplan will drop the Canada-wide feature, cost at least $25 out of pocket and will kill whatever time is left of the current one. Your not-very-likely $30 refund is looking like very thin soup.
Better to run out the booster balance and switch when it's just about run out, maybe keeping some of the Canada-wide minutes in reserve just in case.
Do remember that the base plan offers province wide calling where the booster is good for Canada ...Super helpful, thanks so much!
