Would an incoming call from India use my 1000 international long distance minutes?
I am on 55 $ unlimited Canada wide anytime minutes plan with bonus 1000 international LD minutes add-on included in it.
All incoming calls, no matter their origin, are drawn from your unlimited Anytime Minutes, with no other costs, as long as you are in Canada. Your 1000 International Long Distance Minutes will give you savings on  your outgoing calls.
David wrote:
All incoming calls, no matter their origin, are drawn from your unlimited Anytime Minutes, with n...
Thanks a lot for your reply.
Just a note 🙂
Your have bonus 1000 international long distance minutes which means you can make  international LD calls to India(in your case)without LD charge for 1000 min. It usually $0.05/min with LD saver($3/mo) or $20 for 1000 min/mo
Hey thanks. That's useful to know.
Does this 1000 international long distance minutes reset every month, or is it a one-time block that is permanently used up?
They reset every month. It is not a one-time block.
but how can we monitor it
I replied you on the other posts.
https://community.koodomobile.com/koodo/topics/expense-tracking-for-international-calls-before-invoi...
