why not have monthly add on for data plan now?
Best answer by quasarito 11 September 2013, 14:25
The Canada-wide data plans and Tab Large plans already have data included. The Canada-wide Talk & Text plans have a tiered-use plan. That is if you use no data, you do not pay for it. Otherwise depending on how much you use, you will be charged on the amount of data consumed: $5 up to 25MB, $10 up to 100MB, $15 up to 250MB, and then +$5 for every 250MB tranche above that. See https://shop.koodomobile.com/plans/plans/index.html
1 reply
Userlevel 2
