When roaming in Europe, how do I choose a compatible telcom supplier? Or will my phone connect automatically?.
Phone is a Moto G.  I'm comparing roaming charges and buying a SIM card in Italy.  If roaming I want to be sure to be able to connect to a telecom supplier with services I need.
First your phone needs to be unlocked. If you've never done it or bought it from a carrier it's probably locked. The only reliable way to see is to pop a SIM card from another carrier into your phone. If it is locked, Motorola phones are about 3 to $5 to get an unlock code from eBay or other third-party resellers. After that, you can just pop in any SIM card and it will connect automatically.
Goran wrote:
First your phone needs to be unlocked. If you've never done it or bought it from a carrier it's p...
If you rely on Koodo roaming packages, you will only connect to their roaming partners. You have no choice in the matter. Choose your country in the window below:
https://www.koodomobile.com/help/international-pay-use-roaming
independent overseas suppliers (unlocked phone):
http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data
If you buy a roaming package, the phone will automatically connect to the best network around. Nothing special to do.
