What phone will I be able to upgrade to?
  • 27 June 2015
  • 1 reply
  • 11 views
I have a Samsung galaxy s3 but I bought it back when the s4 just came out. My two year plan I close to ending. What phones will be free during my upgrade? I'm really hoping to get an iPhone 5s.
Best answer by Jonathan I 27 June 2015, 00:35
Well the Tabs are different now. You can take up to $360 off the price of your desired new phone and (probably) keep your plan, but the Tab charge will be added on top instead; in this case it's $15/month. However the iPhone 5S won't be $0 down. It's an expensive phone. So the upfront payment is currently $350 with that Tab plan. There's also the Tab plus, which gives you a bigger discount on the phone, but the plans are more expensive (starting around $80+ after Tab charge).
1 reply
