What is the add on for unlimited incoming US calls? Found the one from Canada to US, but not the other way around.
Hi Patrick, When it comes to receiving calls from the United States it doesn't cost you long distance to receive it. The only thing that happens is when you have a plan that has day time minutes it will go against the minutes you have in your plan. Having an unlimited calling feature to call to the United States will cover any charges you'd receive from calling to the US. Otherwise you can get a call from there or anywhere in the world (as long as you're in Canada) and it won't cost extra. Hope that helps 🙂
Daniel Gunn wrote:
Hi Patrick, When it comes to receiving calls from the United States it doesn't cost you long ...
If you're referring to roaming in the United States then there are roaming packages that Koodo has available for when you are roaming there. I've provided a couple of links for you to have a look at. https://shop.koodomobile.com/plans/add-ons/index.html In this link look under Travelling to the US http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling Hope this helps too! 🙂
