what is koodo HSPA? what is koodo II? and data saver retention?
Userlevel 4
Koodo II is a behind the scenes feature. I wouldn't be concerned with that as a customer. The data saver is included with the new plans so you can remove it from you rlist of features. Koodo HSPA is a network feature which, again, you can ignore since you wouldn't be doing anything with that, yourself. Another behind the scenes feature. There is no point in keeping the old data saver since it would conflict with the data saver in the new plan.
Zaphod Beeblebrox wrote:
Koodo II is a behind the scenes feature. I wouldn't be concerned with that as a customer. The dat...
Koodo II and Koodo HSPA are the same feature, some sort of internal system patch. They changed the name because it was confusing people.
Userlevel 4
I don't see why they need to have those features for customers to see anyway...
Completely agree with Zaphod, I think k it just confuses the customers
