what if I don't go with "unlimited" incoming & outgoing local or canada-wide calls?
What are the charges on incoming & outgoing local and canada-wide calls if I don't have "unlimited" in my plan?
You will use your airtime minutes then when those are exhausted 45 cents per minute is charged if you go over your allotted minutes.
Reena wrote:
You will use your airtime minutes then when those are exhausted 45 cents per minute is charged if...
Also, don't forget that calls are calculated by the minute, rounded up to the nearest minute. So, for example, if you are on a call for 1 minute and 20 seconds it counts as a 2 minute call.
