voicemail and anytime minutes
  • 7 August 2013
  • 3 replies
  • 64 views
If I receive a 2-minute long voicemail during the day, does it use my anytime minutes? Also, if I check my voicemails during the day, does it use the anytime minutes? I am using a Canada-wide plan with 400anytime minutes.
Userlevel 3
Yes. Anytime you check your voicemail prior to when your airtime starts it does use your minute bucket. A lot of people aren't aware of this especially while roaming! I hope this helps!
Yes. Anytime you check your voicemail prior to when your airtime starts it does use your minute b...Ppl leaving a voice mail however does not use minutes, minutes are used just when checking your messages like Rockey stated above.
Yes. Anytime you check your voicemail prior to when your airtime starts it does use your minute b...So check your vm on your unlimited evening& weekend period or use your landline(or your friends phone ) 🙂
