unlimited sms and mms vs unlimited texting
A 30$ talk and text plan has unlimited sms and mms, whats the difference between this service and the add-on: unlimited texting
If it says unlimited TEXTING, it likely includes only sms, but would be a very old add on. The unlimited MESSAGING add on would give you unlimited sms and mms, but cists $5 on top of your plan price.
Sorry your right it says unlimited messaging. So these are the same then? Im looking at the 30$ canada wide plan
sharmvar wrote:
Sorry your right it says unlimited messaging. So these are the same then? Im looking at the 30$ c...
Yes, they're the same. Well, the unlimited messaging part at least,
The difference looks like the add on is international while the original is just regular
All texting with koodo has always been international.
Oh...ok so then they must be the same thing...Sweet just saved 5 bucks a month! Koodo saves the day again! I'LL TAKE IT!
sharmvar wrote:
Oh...ok so then they must be the same thing...Sweet just saved 5 bucks a month! Koodo saves the ...
That's awesome! Make sure you check out Koodo's new promotional plans as well.
