unlimited incoming on 500 Min $45.00 Plan
I have the CAN Data %))MB 500 Minute plan. Most of my used minutes are from incoming calls and I'm going over. Will adding the $10.00 unlimited incoming minutes option fix me up so I no longer have to pay overages on incoming minutes?
Sure it will. If your noticing that ur going over due to a certain thing, an add on that adds unlimited of said feature is going to stop said overages. 🙂. Hope that helps.
Chadwick wrote:
Sure it will. If your noticing that ur going over due to a certain thing, an add on that adds unl...
How do I get this.gift
It's not a.gift per say, but you can add it in Self Serve. I believe it's $10/month.
