I want to change to the $34 60 GB plan, selected unlimited long distance pack but it says 'No perk' selected. I already have the perk and dont want to lose it. Any suggestions?
Hi ​@rclement is this the $39 60 GB plan with the $5 auto-pay discount? If so, the unlimited long distance pack perk is eligible and you can change your plan. If the perk is not active after the plan change, we’ll attempt to add it for you, just let us know here.
Yes, that is the one.. I have changed my plan.. thank you for your response
@rclement Great, the $0 Long Distance Pack perk is still active after the plan change!
thanks
