Transferring Phone and Phone number to Koodo
I want to switch my current phone which is now paid off, as well as my phone number. How do I go about doing this? Also is there any type of charge for doing this?
Everything you need to know can be found right here:
http://help.koodomobile.com/getting-started-with-koodo/moving-your-number-to-koodo-new/how-do-i-move-my-number-to-koodo
Easiest is to visit a Koodo kiosk and sign up for a plan, Tyler. They will explain all the options to you and help you port your number and activate your phone with a Koodo SIM card.
You might need to unlock your phone if you got it from another provider. If it's an iPhone, it's probably cheapest to contact your old provider first, so in that case you will need to do that before you port your number out 🙂
Sophia wrote:
Easiest is to visit a Koodo kiosk and sign up for a plan, Tyler. They will explain all the option...
Thanks for the quick response! What is usually the fee to unlock a phone?
Most providers charge $50, but if it's anything else than an iPhone it's probably cheaper to find a 3rd party unlock service. Some phones can be unlocked for as little as $5!
