Texting and travelling within Canada
I live in BC and may be travelling to Quebec. My question is while in Quebec if I use my cell will I get charged for sending and receiving international texts? I have the $52/month Canada Wide plan (CAN Data 1GB Unltd min). Thanks for any help provided!
You'll be fine. The plan is Canada wide.
Jonathan is right, where your plan is Canada wide, you won't see any charges for roaming in different calling area. When it comes any aspect of the plan you have, you could be all the way to Nova Scotia, and it will not have any effect on your account whatsoever. Hope that helps 🙂
Text messages is always canada wide even if you don't have a canada wide plan
And keep in kind that evenings will be considered in function of the location you are in physically
