Switching Plans between Phones
I want to upgrade both my plan and my daughters plan. I have a great plan at a great rate and would like to assign that to my daughters phone then get myself a new plan, is that even possible?
Hey Shauna. Just put her SIM card number on your account and voila! Her SIM card will have your plan! There is no possible way to transfer!
Robert wrote:
Hey Shauna. Just put her SIM card number on your account and voila! Her SIM card will have you...
Wouldn't it also be her plan and phone number?
Couldn't she "transfer" her number afterwards?
Your plan is attaching to your phone number. So if you give your plan and phone number to your daughter( give your sim card to your daughter), she can use it. Then you can pick/upgrade your plan on her sim card. That means you have to use her phone number until you change it.
