Roaming UK
  • 13 October 2021
  • 1 reply
  • 19 views
I am travelling to the UK next month, I only need to text and call. How can I do this? And how much will it cost?
1 reply
By far the cheapest option will remain easy roam, unless you will only call 2-3 minutes a day. Calling is 2 dollars a minute and outgoing sms is 60 cents each. Or you can use “easy roam” for 13 dollars per 24 hour period. Another option is to get a local Sim card, with the following options available :
https://prepaid-data-sim-card.fandom.com/wiki/United_Kingdom
