Roaming - options for add ons
  • 24 September 2018
  • 1 reply
  • 165 views
Is the only option for an add on when traveling to the US to add the easy roam? There used to be where you could add so many text messages for a fee for a certain length - is that not an option anymore?
Best answer by BobTheElectrician 24 September 2018, 15:42
You can turn off easy roam and use the pay-per-use system. $5 for the first text, next 99 to the end of your billing cycle are free, then it's rinse and repeat. Only recommended for texting... the other pay-per-use rates are pretty steep, including those related to call forwarding, etc. in the lower tab on this page:
https://www.koodomobile.com/payperuse?INTCMP=KMNew_EasyRoamCTA_PayPerUse
1 reply
