pre owned phone witj current plan
  • 28 March 2021
  • 1 reply
  • 29 views
Hi all, sorry if this has been asked I can't seem to find a definite answer.
If I buy a pre owned phone from Koodo and say the tab is 10 a month. Does that just get added to my current phone plan or would I need to sign up for a new plan entirely.
Thanks!
Best answer by Allan M 28 March 2021, 15:38
1 reply
As long as your plan satisfies the tab requirements and isn't expired you can keep the plan.
Easiest way to check this is to simply go through the checkout process and see if it let's you keep it or not.
