Plan with 0 minutes
  • 10 April 2021
  • 1 reply
  • 41 views
I recently switched to a data only plan with 0 minutes. Talk time is 0.7 cad/min. I am wondering whether I pay for incoming calls as well.
Thanks very much.
1 reply
Yes, you would. It really is a terrible plan. Is there any reason why you didn’t just go with a prepaid plan instead? Most providers offer a data add-on and calls are much more reasonably priced. Check Public Mobile’s $25 plan that also has 1GB of data, that is probably less than you pay now!
