Phone won't work in the USA
i recently travelled to the USA and tried to add the talk and text package. I didn't add it before I left. when I got there, the phone wouldn't work. said emergency calls only, and I was not able to text the code to add the package. So, then I figured I would try the website option. that wouldn't work either, because I couldn't keep an internet connection long enough to do it. The internet was working fine, as I was able to get on with my blackberry playbook and my friend who was with telus had no problem. my phone is a Galaxy Ace 11. would like to know why this happened. considering changing providers if this is going to be an ongoing issue for international travel.
Well, it has likely nothing to do with koodo themselves. Telus owns koodo and guaranteed they have the same roaming agree my with US carriers if you are a monthly customer and mot prepaid. So, I'm convinced it's more to do with your phone. You can be with the same phone company and 2 different phones could have different receptions in the same spot. Other than that, actually looking at your phone it's hard to tell exactly what the solution might be.
Are your payments up to date?
Yes, they are.
Userlevel 3
Hi Kathleen, For next time, try to search manually for the network by following these steps: Setting/More/Mobile Network/Network Operator/Search Network. This will help 🙂. ________________________ If you see a good answer, give it a star.
