Phone Upgrade and keeping Data add-on
  • 7 November 2020
  • 7 replies
  • 183 views
I’m thinking of getting a upgrading to new phone and I would like to keep the same plan.
Will I be able to keep my 5GB data add-on if I keep the same plan or I’m going automatically lose any addon after upgrading to a new phone?
Best answer by Bernard Koodo 9 November 2020, 04:21
@Mikek7 As per Dennis and Dinh above if you keep the same plan the 5gb will stay. Make sure you upgrade online to save the $45 connection fee charged by stores.
If you can keep your current plan when upgrading, that add-on 99% likely stays, IMO.
However,  you can always get a confirmation from a rep via Facebook messaging before upgrading. It will help in the case there was an error or issue with the purchase.
If your plan doesn't change then your add-ons will remain
Is there any Koodo moderator or employee on this forum that can confirm this.
Thanks
Yes there is, I’ll flag one see he can confirm this.
Thanks for confirming Bernard.
Wrong, I just called in and Koodo informed me I cannot keep the 5gb add on if I do a hardware upgrade and keep my current plan. Can you confirm if things changed?
