No LTE on Tablet Plan
  • 9 November 2018
  • 2 replies
  • 174 views
So I just got a new tablet plan ($15/3GB), but it appears to only connect to 3G. I’m using it on an iPad Pro and I already changed the APN to sp.koodo.com (although I don’t think it has anything to do with this). I tried restarting, taking the SIM card out, resetting my network settings, and checking whether ‘Enable LTE’ was ticked on to no avail. It’s odd because my iPhone (same with Koodo) connects to LTE.
Best answer by Dennis 9 November 2018, 21:39
Try using your tablet sim in your iphone and see if you get LTE
Hi, Dennis. I just did what you suggested and it worked! Once inserted in my iPhone, it started to connect to LTE, and when I put it back into the iPad, it connected to LTE as well. Thanks!
