need help getting the travel add-on
  • 17 June 2015
  • 1 reply
  • 373 views
I want to get the travelling add-on so I can text while overseas. I found instructions on how to do that but the feature the instructions talk about does not appear in add-ons. How can I get this feature? Also, is there any way to call an agent if i can't solve my problem?
Best answer by Yannick 18 June 2015, 13:47
Hi Laura, which add-on are you trying to add? Where are you travelling to ? You can information about using your phone abroad on this link http://koo.do/Im7Mcg 🙂 ________________________ If you see a good answer, give it a star.
1 reply
