my phone is on vacation suspension ....i will be home soon and cant seem to activate it
How long has it been on Seasonal Hold?
Have you tried to change your plan on Self Serve?  A Seasonal Hold is just a "plan" so to activate, you just need to change to a current plan
since november
Yes, like Dennis said you have to select a new plan , or if the plan you had before vacation is still available and you liked it, you could opt in for that plan. All this can be done through Self-Serve.
ok thanks i will try that
