Long distance plan add on ect, for Russia?
I was wondering if there is a long distance plan add on ect, for Russia? Or even what the rate would be for incoming calls from there? Thank you.
Regular rate for Russia is $0.50/minute. If you add the long distance add-on ($3.00/month) then it's $0.15/minute to call. http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance
Ivan's suggestion is great. No additional charge, other than your regular minutes, for incoming calls from Ru or anywhere else.
