is there $28 plan available with 250 minutes and no data. I was told there was.
Userlevel 3
Hi June, yes there is a $28 plan with 250min for some reason Koodo doesn't advertise this plan but it is available for you.
Thank you. I would like to change my plan to this one. How do I do that?
Thankyou. I would like to change my plan to this one. How do I do that?
Userlevel 3
All you have to do is go on to your self serve account and make the change as long as you are already on the new TAB system. If you are still operating under the old TAB system you will have to call in to switch it over but there is no charge for this call because you can not do it yourself in self serve. Hope this helps. 🙂
On the $28 plane is in coming call free?
No jacqueline. The 200 mins or 250 mins you get is for incoming and outgoing both. But evenings after 5 pm untll 8 am and weekends are unlimited calls in and out.
