Intl Voice roaming.
  • 29 September 2021
  • 3 replies
  • 30 views
Unable to add Intl. voice roaming. Get the message you’ve selected one or more add-ons that are already on your account. If you wish to add a new add-on, cancel the existing one and try again. I have
  • Pay-Per-Use Intl Long Distance$0.00
  • International Data Roaming
Unable to remove Pay-Per-Use Intl Long Distance so I can try adding Intl. voice roaming.
Need help as I will travel very soon,
Best answer by Robert T 29 September 2021, 04:37
And now it works.
Sometimes, it's only a small bug. Happy to know your problem is solved.
Sometimes just enabling easy roam fixes the issue too.
