International roaming add-on - will it replace my monthly plan?
I am travelling to Costa Rica for 2 months and am looking to add the international roaming to my phone. Will this or can it replace my regular monthly phone plan? I currently have the $60/month plan with 1000 minutes and 3 gb data which obviously I won't be using while in Costa Rica. Thank-you!
No, your base plan needs to be active so you can roam. You could change it to a lower priced plan, but you may not be able to choose a plan similar to the one you have now on your return.
Also if I'm away for 2 months will I be able to add on another international roaming when it runs out in 30 days? I won't be in Canada to add it.
Leisha Sagan wrote:
Also if I'm away for 2 months will I be able to add on another international roaming when it runs...
You should be able to do it through the Koodo App downloaded to your phone.
If you are going to be away for 2 months, consider unlocking, putting your account on seasonal hold and using a local SIM
http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data
You will have to choose from available plans when you return, but in the meantime only spend $15 a month with Koodo to hold your number.
