International long distance rates- will I keep them if I upgrade to a new plan?
I've been with Koodo now for almost 4 years- same plan all this time, it used to be called Canada -Wide Data Double 45
Now I am thinking of purchasing a new iPhone on Tab Medium and I want to know if the rates that I 'm charged for calling Greece (with the $2 add on) at 5 cents/minute can be kept or if I'll have to switch to $1/min which is the current rate .
Can I keep this great deal that I've had since April 2013 or is upgrading going to cost me $1/min and $3/month for the add on?
You can add the LD saver again, Sofia, but it now costs $3 instead of $2. You should be able to call Greece for $0.05 with that though.
Sophia wrote:
You can add the LD saver again, Sofia, but it now costs $3 instead of $2. You should be able to c...
Wait wait!! I just checked the website http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance and you are QUITE right... Greece is not in the list and would be $1 instead of $0.05. I am not sure if you can keep this add-on you have now while changing plans... I'll inquire for you.
Usually, when you change plans, you get to keep all add-ons. Never lost any add-ons when I switched plans.
Hi Sofia,
You can change your plan without having to change your add-ons. As long as you keep the $2 LD saver, you'll keep your 5 cents/minute rate for calling to Greece.
Thanks
