International incoming calls?
Hi, I have a 45$ monthly plan with unlimited incoming calls. But, do "incoming calls" mean international incoming calls?
Yes. You can receive international incoming calls without charges, as long as your phone is in Canada.
Mayumi wrote:
Yes. You can receive international incoming calls without charges, as long as your phone is in C...
Wow Mayumi. You are up early!! 🙂
Hi we have the $60 per month regarding. Koodo plan. Have added on texting for uk. While here in uk with my phone will I be charged extra for incoming calls from canada
Userlevel 4
Hi Tia! Yes, you will be charged for any incoming calls if you answer the phone. You can always not answer and send them a text 🙂 Hope that helps.
Is it also valid if I add the unlimited incoming calls option to my current plan, which charges for incoming calls? I think that should be the case, but still wanted to be sure before paying for it.
Nada wrote:
Is it also valid if I add the unlimited incoming calls option to my current plan, which charges f...
Yes, no additional charges as long as you: Are in Canada when you receive the call & Have the unlimited incoming calls add on -or- incoming calls are included in your plan
Thanks Chad. And if I pay for the unlimited incoming call add on today, I will have that option (domestic + international incoming) for 1 month starting as of today, right?
It's pro rated, it renews on your billing cycle until you remove it. It'll be active today after you add it. When you get the bill you'll see a charge from today to your bill date, then another charge to pay for the add on for the next month.
Great. Thanks.
I do have a last question. Is it the "Minutes Local Income Unlimited" ($10.00) add on? I was confused by the "local" part.
As long as you're on a plan that says Canada Wide as part of its name, you never need to worry about what's local because Canada becomes local.
